EV indicator not appearing
86,000 MILES
BEBOBEBO
  • 116 POSTS
I have problem in high voltage battery and i did replace around ten cells.
Next day the mechanic remove the catalytic converter (manifold and converter)
and put another one that is empty from reduction oxidation pads for transient use.
And told me to return after two days until new catalytic converter is available to install it .
Once return home i noticed that EV mode did not appear again in my dashboard. my question is, what do you think is the cause?
Is it battery problem or catalytic converter?
Note: after change cells the EV indicator was present when battery charged , but after changing catalytic converter thus problem appeared. no trouble codes appear and faulty signs appearing on dashboard.
Please help.
Mar 29, 2018 at 1:58 AM
  • 55,649 POSTS
The EV light not showing up means there is a problem with the system lets start by running the codes. Here is a guide to help us get started:
Please let us know what you find.
Cheers, Ken
Mar 30, 2018 at 4:48 AM
