The engine is mixing water and oil again
130,000 MILES • 2.0L • 4 CYL • 2WD
MOTHAE
I have just replaced a cylinder head casket and it ran well when started the first time but eventually mixing oil and water again in hours.
Aug 12, 2019 at 7:08 PM
MOTHAE
It seems to have been throwing a lot of pressure to the coolant and disturbs a normal flow of water throughout the cooling system.
Aug 12, 2019 at 7:23 PM
SCGRANTURISMO
  • 4,897 POSTS
When you changed the head gasket did you get your cylinder head shaved at a machine shop?
Thanks,
Alex
2CarPros
Aug 12, 2019 at 7:25 PM
MOTHAE
Yes, it was skimmed and pressure tested with new valve seals.
Aug 12, 2019 at 7:29 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, so let's do a compression check and make sure that the head gasket took. Here is a link for you to go to down below explaining how to do it:
Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 13, 2019 at 8:31 AM
