the egnition where you put the key in to start up
2001 JEEP GRAND CHEROKEE LAREDO
67,000 MILES
LEIMOMI
It seems that the egnition has locked up cause it wont turn at all we tried turning the steering wheel back and forth we even sprayed a little bit of WD40 into the keyhole its just locked up and wont turn
May 25, 2013 at 2:19 AM
CJ MEDEVAC
  • 11,004 POSTS
HAVE YOU TRIED THE "SPARE KEY"?
SOMETIMES THE "PRIMARY KEY" GETS REALLY WORN
OTHER THAN THAT......PLASTIC USED TO BE USED FOR "IMPORTANT PARTS" SUCH AS THE OLE SHIFTER KNOB............NOW IT TAKES THE PLACE OF EVERYTHING, THAT USED TO BE METAL
AND IT COULD BE OTHER STUFF TOO!
SO I'M GONNA SUPPLY YOU WITH THE TOOLS YOU NEED..........SEE THIS LINK, YOU WILL NEVER FORGET ME!........YOU WILL USE IT FOR A LONG TIME
https://www.2carpros.com/questions/1989-jeep-cherokee-hook-cable-vent-air-flow-comes-out-vents-except-defrost
NOW.........IF "ADVANCE AUTO PARTS" IS AVAILABLE TO YOU......I MAYBE ABLE TO SAVE YOU SOME CASH.....REMEMBER THIS....."A124" IS STILL WORKING!.....I JUST BOUGHT $77 IN PARTS AND ONLY PAID $52 FOR THEM YESTERDAY!!!!........IF NOTHING ELSE, THIS METHOD MAY WORK FOR YOUR LOCAL STORE(S)
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
YES, I HAVE LINKS INSIDE OF LINKS, (DON'T GET BORED), THESE MAY SAVE YOU BIG $$$ ALL THE WAY AROUND
KEEP US POSTED ON PROGRESS
THE MEDIC
May 25, 2013 at 3:20 PM
