the temperature gauge drops off to 0. the fan runs for a while after engine is off, but thee engine is not hot.
Feb 6, 2021 at 12:46 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
Sounds like you might be having an issue with the coolant temperature sensor. It might be faulty and giving your cars computer a false reading thinking its running hot or overheating. Here are 2 tutorials for you to view about coolant temperature symptoms and function:
I've attached picture steps below of the coolant temperature sensor location and how to replace on your vehicle. Hope this helps and thanks for using 2CarPros.
