What are the correct piston ring sizes for the K24A3 engine?
165,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
IONUT84
I have a 2003 Honda Accord Tourer with a K24A3 engine (there are different versions of the K24A engine for different markets (Europe, Australia, Japan; I have the European version). I'm interested to replace the piston set, and I found contradictory information about the correct piston ring sizes for the K24A3. Can you please provide me with the correct ring sizes?
Jun 25, 2024 at 6:47 AM
  • 55,721 POSTS
The K24A3 engine typically uses the following piston ring sizes:
Top Ring: 1.2 mm
Second Ring: 1.2 mm
Oil Ring: 2.0 mm
Let us know if you need anything else.
Jun 25, 2024 at 7:19 AM
IONUT84
That's very helpful, thank you very much!
Jun 25, 2024 at 10:25 AM
  • 55,721 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Jun 26, 2024 at 3:07 AM
