Will not crank and economy mode activated
40,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
VICKYBEE007
  • 8 POSTS
The car does not crank at all. I checked the battery voltage and connector, everything was okay. I also checked the fuses on the PSF and the BSI, everything was okay too.
I have also checked the condition of the starter motor, it is working fine. I need your help please.
Apr 28, 2018 at 1:16 AM
  • 55,649 POSTS
Can I ask if the security light is flashing when you try to crank it over? If so please lock and unlock the car using the remote.
Please let us know.
Cheers, Ken
Apr 29, 2018 at 4:44 AM
VICKYBEE007
  • 8 POSTS
Not at all sir. There was no security light flashing on the dashboard.
Apr 29, 2018 at 5:19 AM
  • 55,649 POSTS
Does it seem like everything electrical is working but the engine is not turning over? (starter not working). There is a starter relay I would check here is a guide to help you.
I am not sure where the relay is because I do not have repair information. If you have the owners manual it will tell you where the relay is can you upload an image of its location it would be great.
Apr 30, 2018 at 4:10 AM
VICKYBEE007
  • 8 POSTS
Okay then. I will do that tomorrow because I have closed for the day.
Apr 30, 2018 at 4:22 AM
