the car statrted today after sitting for the winter
178,000 MILES • 1.9L • V8 • RWD • AUTOMATIC
WAR_ANIMAL
Car started ran smooth but than started racing shut off the car cranks misfires but won't start its getting fuel.
Apr 23, 2014 at 10:49 AM
  • 110,251 POSTS
First, make sure that the fuel pressure is within the manufacturer's specs and not too high or low due to a regulator issue. If the check engine light is on, have the computer scanned to determine trouble codes which can lead you to the problem.
Apr 24, 2014 at 10:33 PM
WAR_ANIMAL
The car started checked and cleaned all spark plugs now firing found vacuum hoses loose no idling now
Apr 27, 2014 at 7:09 AM
  • 110,251 POSTS
If you have repaired all vacuum leaks, check to see if the idle air control valve is working properly.
Apr 27, 2014 at 10:06 PM
