Will not idle or move when transmission is put in gear
20,000 MILES • AUTOMATIC
1TJ
The car starts and idles great, but when I put it in gear it will not idle up nor will it move.
Sep 9, 2019 at 7:23 AM
  • 55,673 POSTS
Are the miles you listed correct 20,000? If not is sounds like the engine is in limp mode due to a dirty throttle body. here is a guide that will help you fix the problem:
We should runt he codes as well.
Sep 11, 2019 at 3:58 AM
