I have replaced a bad starter after having it tested, but the new will not engage unless the starter is jumped from the battery. What should I check first as in ignition switch? any known fuses? I have swapped the starter relay with the accessory delay relay and result. Just need some advice on where to start. Appreciate any help.
Feb 1, 2020 at 1:22 PM
