the car has check engine light on code p1320?
180,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
HOWARD KYI
replaced number two , and number four cylinder coil pack ( ignition ) , but , check engine light still come on with p1320 , what do I do next now ?
Feb 14, 2016 at 8:27 AM
SQM
  • 6,383 POSTS
This code can be triggered due to a few different factors.
it could be due to a wiring issue for the ignition coils, faulty crank sensor or circuit.
The best option would be to take a step-by-step approach and go through the possibilities and find out the issue.
I have attached the trouble shooting guide for the code P1320 below.
Go through the steps as that can help you determine the reason for the code.
Jan 15, 2022 at 12:37 PM
