The car continues to run after switching off for a short period
1.4L • 4 CYL • FWD • MANUAL
GARFIELD89
After switching off my vw polo r reg, it continues to run for a short period, what could this be? Many thanks Mitch.
Mar 19, 2014 at 5:47 AM
CARADIODOC
  • 34,386 POSTS
I ran into this once where someone hot-wired the radiator fan to run all the time rather than fix the problem the right way. When the ignition switch was turned off, the spinning fan motor acted as a generator and supplied the current needed by the Engine Computer for about three or four seconds.
Mar 19, 2014 at 8:26 AM
GARFIELD89
Thank you for replying, any suggestions on how to fix this problem. Kind regards Mitch.
Mar 19, 2014 at 10:28 AM
CARADIODOC
  • 34,386 POSTS
What I referred to would have been a modification someone did if the radiator fan wasn't turning on when it was supposed to. The clue would be the fan runs now anytime the ignition switch is turned on. If that's the case, you'll have to find where they spliced the fan circuit to a hot circuit and undo that.
Mar 20, 2014 at 10:49 AM
