It will not open ,I have tried everything, I close it down at the tire shop and I got home it would not open.
Sep 7, 2015 at 9:13 AM
MIKE H R
MEMBER
sounds like something go t stuck in the latch. check the inside at the latch to see if anything is there. If so try to remove it. You can also try with the latch switch in the open try to wiggle it so the latch lets go in order to open the hatch.
Sep 9, 2015 at 6:43 AM
