The amount of air from AC fan is very low.
350,000 MILES
HASSOOO
HI, I have a question, I repaired my A/C four to five times from Mechanic, but every time I get it repair, it works fine for 3 to 4 days then stops working efficiently. Yesterday Again I changed the mechanic he found some leakage and fixed it then for couple of hours it worked fine and after that same problem happened but this time airflow is very low, I can not even feel that air is coming out of car AC windows. Can Cabin Filter blockage cause gas leakage, please advise.
Aug 18, 2013 at 9:18 AM
WRENCHTECH
  • 20,760 POSTS
He apparently doesn't know how to detect a leak. I would suggest a different shop that specializes in AC. Most independent shops think they can repair AC but most can't.
I would have them install U/V dye with the refrigerant so the leak can be found later.
Aug 18, 2013 at 10:00 AM
HASSOOO
thanx for your reply, but can you please tell me why amount of air is very low, is it because of bad Air Cabin filter ?
Aug 18, 2013 at 10:09 AM
WRENCHTECH
  • 20,760 POSTS
It could be but that also needs to be checked out
Aug 18, 2013 at 10:12 AM
HASSOOO
Thank you for your help.
Aug 18, 2013 at 10:15 AM
