the air heater dont work just cool air
145,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
VAGRE
well when i start de tyruck and the machine starts to heat up picks to have overheating and the heater dont work just cool air end then the engine died and dont start again well only when the machine is cool
Feb 21, 2015 at 3:53 AM
  • 31,937 POSTS
You may have a coolant leak, get the cooling system pressure tested and rectify any leaks, replace the thermostat and get the radiator core cleaned the heater is not working and the over heating is probably due to air in the cooling system.
Feb 21, 2015 at 6:17 AM
VAGRE
thank you very much well i changed the termostat and i cleaned the radiator and i changed the antifrize but like u say i have to check for any leaks in the cooling sistem
Feb 21, 2015 at 6:42 AM
  • 31,937 POSTS
OK, re post if you still have problems, good luck and thank you for using 2CarPros.
Feb 21, 2015 at 6:44 AM
VAGRE
hi just to tell you thank yuou very much i fixed all ready de cooling problem but now still have the other thing after 20 minutes or more the engine loses strength its like when you disconect the air filtrer and the motor wants to turn off.
Mar 1, 2015 at 5:23 AM
  • 31,937 POSTS
Check for codes and check for a blocked fuel filter, start here.
Mar 4, 2015 at 2:32 PM
