Where is the actuator for the temperature blend door located?
85,000 MILES • 8.1L • V8 • 4WD • AUTOMATIC
VDADAMS
Where is the actuator for the temp blend door for the passenger side located?
Aug 3, 2024 at 3:20 AM
  • 55,834 POSTS
Sure, here is a guide that shows you where each of the blend door actuators are:.
Check out the images below as well. Check out the images (below). Let us know if you need anything else.
Aug 3, 2024 at 5:12 AM
VDADAMS
I need to know about the passenger side actuator???
Aug 5, 2024 at 4:50 AM
  • 55,834 POSTS
Can you please looks at the images and guide I sent?
Aug 5, 2024 at 4:51 AM
VDADAMS
Your video is good for the actuator under the glove box, but I do not see any good diagrams or videos for replacing the actuator that controls the passenger side of the vehicle. Do you have a video for that?
Thanks,
Dean
Aug 6, 2024 at 1:26 AM
  • 55,834 POSTS
If you scroll down on the guide I sent it shows the right-side actuator but here, is it. Check out the images (below). Let us know if you need anything else.
Aug 6, 2024 at 2:00 AM
