Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
RAV4
Climate Control
Air Conditioner
Not Working
A/C will not work
1996 TOYOTA RAV4
230,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOSEPH ARMAND
MEMBER
Cooling fans are not working.
Dec 29, 2018 at 10:51 PM
Experienced Mechanic
Good morning,
Did you verify power to the fan connector? you can use a test light or voltmeter.
I attached a wire diagram for you to check the fuses listed for power on both sides. I would start there.
Image (Click to enlarge)
Apr 13, 2021 at 3:24 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
