Testing wires TCM to tranny
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BOBFAIR
In tech manual for this vehicle it asks to test circuits to ground. How do Ido this? It says disconnect pcm/tcm connectors and disconnect the tranny solenoid connector then test to ground. Do I need a jumper to ground on one side and then use multimeter to test to ground and the other side of wire?
May 19, 2019 at 5:32 AM
  • 110,251 POSTS
Welcome to 2carpros.com
As far as testing to ground, you only need a multi meter to test for continuity. Both components will have their own ground even though they are disconnected. Therefore, check for continuity between the component and a known good ground.
Let me know what is going on or if you have other questions. I'm a bit confused with exactly what you are checking or checking for.
May 19, 2019 at 1:19 PM
