In tech manual for this vehicle it asks to test circuits to ground. How do Ido this? It says disconnect pcm/tcm connectors and disconnect the tranny solenoid connector then test to ground. Do I need a jumper to ground on one side and then use multimeter to test to ground and the other side of wire?
May 19, 2019 at 12:32 PM
