testing ignitio swithces
75,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DAVIDE123
  • 26 POSTS
Was talking to mhpautos about a problem he said to repost. But all the info is at:
https://www.2carpros.com/questions/no-power-to-anything-needing-key-on
Trying to get where to test on back of plugs and what is what
here is my last reply:
January, 31, 2016 AT 1:47 PM
I can test back of plug but not sure which is which.
Back of 8 Pin: BLK/RED [ ] [ ] BRN
BLK/BLU [ ] [ ] BRN/WHT
BLK/YEL [ ] [ ] (OPEN)
BLK/WHT [ ] [ ]BRN/RED
Feb 1, 2016 at 1:18 PM
  • 31,937 POSTS
Finaly found what i was looking for, this should help you with the switch wiring.
Feb 1, 2016 at 8:09 PM
DAVIDE123
  • 26 POSTS
Thanks I will see if I will look it over and see if I can figure anything out.
Appreciate your help.
Feb 2, 2016 at 1:15 AM
  • 31,937 POSTS
OK, keep in touch.
Feb 2, 2016 at 4:39 AM
DAVIDE123
  • 26 POSTS
Ok I figured out what goes to what sort of..
I checked 3 input to switch brown from fusible link to Am2 is 12 v...steady ok. But white was not clear at first I saw 12 v then I turned key to check one of its outs nada, but I lost 12 v in (white) AM1...
So currently on my way to work again. I think it has something to do of not getting 12v to arm 1. (wht).
According to the diagram it comes directly from a fusible link, (on the battery or somewhere else?
Feb 2, 2016 at 5:38 AM
DAVIDE123
  • 26 POSTS
There are 3 fusible links on right at the + side of the battery they all look to be making contact (not burned open. one is blue when is red one is green
Feb 2, 2016 at 5:42 AM
DAVIDE123
  • 26 POSTS
So... it seems to go>>> +Battery terminal > Lug > Fusible link (not sure which one r/bl/grn) > Cable (wire) to ARM 1. What do you think?
Feb 2, 2016 at 5:49 AM
DAVIDE123
  • 26 POSTS
Mhpautos let me know if you an idea
Feb 3, 2016 at 4:42 AM
  • 31,937 POSTS
Start with checking the continuity of the fusible links, we need to know if they are OK.
Feb 3, 2016 at 3:13 PM
DAVIDE123
  • 26 POSTS
I took off the connector and boot at the
+ term with the 3 FLs. Clipped on to connector and got continuity at each place they connect. They do not seem to want to unplug. also the visual looks ok..
Feb 4, 2016 at 1:39 AM
DAVIDE123
  • 26 POSTS
Ok I watched a vid and pulled fuses... all have continuity at there lugs.. Currently the are not installed...
Feb 4, 2016 at 2:25 AM
DAVIDE123
  • 26 POSTS
I have put FusLinks back I am get a voltage +12 to arm2 but a drop at arm 1 (white wire from battery). I do not see anything between the switch and the fusLink.
Is there something that can cause the V to drop (getting about 9v) ...
Feb 5, 2016 at 10:32 AM
DAVIDE123
  • 26 POSTS
Again thanks for your help, I guess I should start removing the wire shroud and see if there is a problem in the wires. Unless you think something else may be causing the drop
Feb 6, 2016 at 2:22 PM
  • 31,937 POSTS
Try running a jump wire to see if things improve, if you head down the path of checking the loom check for any points that have a bend or are unsupported as this is where you may find a damaged wire.
Feb 6, 2016 at 3:00 PM
DAVIDE123
  • 26 POSTS
Thanks, for your suggestions. I assume the loom is the serrated plastic that covers the wires. Are there points where I can jump as I found a wire diagram.
BUT it shows sw ------continue F Link --- Bat+
Feb 8, 2016 at 1:58 AM
DAVIDE123
  • 26 POSTS
Ie no junction just strait wire. Thanks for your support...
Feb 8, 2016 at 1:59 AM
DAVIDE123
  • 26 POSTS
ok Im done
Feb 8, 2016 at 9:16 AM
DAVIDE123
  • 26 POSTS
Ok I m done. Thank you for all your support....
I undid the shroud. at the junction the wire was disconnected. It looke like blue perhaps old terminals
Feb 8, 2016 at 9:17 AM
DAVIDE123
  • 26 POSTS
The white wire had no connection.. At the junction I cut the wires and splice a new wire. (soldered in) reassembled taped WOW crazy I am tired....
test drove OF now.. Again thanks and hope this helps someone else trying to figure why they have no power to anythingggggggggggggggggggggggggggggg.....
God less....Davide
Feb 8, 2016 at 9:20 AM
DAVIDE123
  • 26 POSTS
sorry GOD BLESS Davidee..............
Feb 8, 2016 at 9:21 AM
  • 31,937 POSTS
do you have continuity down to the ignition switch? sorry but a lot of water has gone under the bridge since we first looked at this problem, i an re loading the info into my head so we can pick up and move on.
Apr 23, 2016 at 10:15 AM
