Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sierra
Ignition
Coil
Test
testing coil near plug
2003 GMC SIERRA
200,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
GREMLIN_MECH
MEMBER
1 POST
how to test coil near plug coil
Apr 8, 2016 at 7:23 AM
HMAC300
Experienced Mechanic
with an ohm meter see video attached
https://youtu.be/1zQQy9noYQ0
Apr 8, 2016 at 8:37 AM
AUTOTECHCHICK
MEMBER
You could test it as in the video posted above, but the easiest way is to swap it with a coil from another cylinder. Then, by monitoring a scan tool, check to see if the misfire has moved along with the coil.
May 11, 2016 at 1:22 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
