Testing alternator, charging system light is on?
25,000 MILES • 2.3L • TURBO • 2WD • AUTOMATIC
RAMJACCORP
  • 27 POSTS
The vehicle listed above is an S (supercharged) Battery is good, but the charging system light is on. Tested voltage at battery posts while running, and it was below 13, so it looks like battery isn't charging. I had to remove the charge air cooler to access the connector plug and post from the top. I want to test voltage from the post, before assuming the alternator is toast, but can I safely run the engine with the air cooler removed? Can't access the buried alternator with the cooler in place.
Sep 6, 2023 at 3:02 AM
  • 55,711 POSTS
You should be able to but if you upload images of what you are talking about, I can tell for sure.
Here is a guide to help with the test:
Please let us know how it goes.
Sep 6, 2023 at 5:57 AM
RAMJACCORP
  • 27 POSTS
Thanks for the quick response, Ken! I already watched that video - very helpful. I've attached a couple images - hope they're useful. I don't want to risk doing any damage to the supercharger or engine. I think they built the entire car from the alternator out. ;-)
Sep 6, 2023 at 7:09 AM
  • 55,711 POSTS
You should be okay, if the engine goes to full throttle shut it off, I would not rev the engine. Let me know what happens.
Sep 8, 2023 at 8:28 AM
RAMJACCORP
  • 27 POSTS
Just realized I never followed up with you on this one. The problem just went away one day. I still think that the voltage regulator is wonky, though. Since I can't access the post to run a test on it, I'm stuck with it for now. I was able to get the wiring harness open and gave contacts a good cleaning. It needs a new serpentine belt, for sure.
May 1, 2024 at 8:40 AM
  • 55,711 POSTS
Okay, problems that go away on their own are welcome :) Thanks for letting us know, we are here to help, please use 2CarPros anytime.
May 2, 2024 at 5:48 AM
RAMJACCORP
  • 27 POSTS
I have an update on the alternator issue, and a follow-up question for you. I found a post on a forum that said the Millies tend to have an issue where the alternator gets "gummed up," and stops charging the battery. The recommended fix was spraying it down with WD-40 and giving it a few taps to shake the buildup loose. I tried that, and it worked! My question is: Is there any way to ensure that the alternator won't just crap out again while I'm driving, or is it time to replace the alternator to play it safe? Pretty pricey job, because it's a nightmare to access the thing on this car.
Dec 16, 2024 at 2:49 AM
  • 55,711 POSTS
Yes, I would replace the alternator because it sounds like the brushes are worn out, this is why the wd40 and tapping will get it to work again.
Dec 17, 2024 at 2:19 AM
RAMJACCORP
  • 27 POSTS
Thanks, Ken. Hard to believe the brushes could be worn out on a car with under 30K miles (yep, you read that right), but I guess maybe it's just old age and corrosion.
Dec 17, 2024 at 3:21 AM
  • 55,711 POSTS
If it only has 30k it might be okay, I didn't expect that low of mileage.
Dec 18, 2024 at 1:38 AM
RAMJACCORP
  • 27 POSTS
Yeah, the car was my "weekend toy," back when I had enough money to do that. The alternator is a crapshoot, unfortunately. It's too buried to yank out and have bench-tested, so there's no way to tell if it'll fail again while I'm driving. The guy who designed that engine compartment was a sadist!
Dec 18, 2024 at 3:08 AM
  • 55,711 POSTS
lol yep it happens, I would run it until the battery light comes back on which it might not happen.
Dec 19, 2024 at 2:37 AM
