TEST CRANKSHAFT POSITISION SENSOR
2007 NISSAN ALMERA
1,500 MILES • 4 CYL • FWD • MANUAL
HABIB ADAM
  • 16 POSTS
When I crank the car, it cranks, but does not start. And I want to know if the Engine Control Unit (ECU) is faulty. If I test the crank sensor, will the sensor shows signal if it work properly?
Mar 15, 2016 at 6:51 AM
HABIB ADAM
  • 16 POSTS
Please, the security light does not illuminate on the dash, but when I crank the engine there is no spark. and I want to know if the ECU is faulty and I test the crank sensor ,will the sensor show signal if it is working ?
Mar 15, 2016 at 6:32 PM
RENEE L
  • 1,260 POSTS
We sincerely apologize for the rudeness of that moderator. We have a zero policy for that type of behavior and action has been taken. There is a great video that will help you with your problem. Go to
www.youtube.com/watch?v=RvuzZJqQDf4
Mar 17, 2016 at 9:43 AM
