Terrain management system fault on?
150 MILES • 6 CYL • 4WD • AUTOMATIC
MICHELLE LEIGH WHITE
It's a tool for terrain management system fault on and need to reset it. The vehicle won't go in reverse and barely forward.
Dec 31, 2022 at 5:46 AM
  • 110,248 POSTS
I'm not sure what you need. Is it a tool to delete the fault code? If that is the case, you need a basic OBD2 scan tool. If you don't have one, most parts stores will lend one to you.
Here is a quick video that explains how to retrieve and clear code:
https://youtu.be/b2IJGfImVvw
If you are looking for something different, let me know.
Take care and Happy New Year,
Dec 31, 2022 at 10:40 AM
