Terrain management fault
99,000 MILES • V6 • 4WD • AUTOMATIC
CBARBER
When starting the car this light comes on: Terrain management fault.
Nov 12, 2017 at 11:39 AM
  • 55,711 POSTS
There is a problem with the a sensor or controller. Please scan the system of codes. If you scan the ABS system it should come up with a code that we can use to fix the problem.
https://youtu.be/rTtAnsOlZU4
Please run this test and get back to us.
Cheers, Ken
Nov 15, 2017 at 10:38 AM
