Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine
Serpentine Belt
Diagram
Serpentine belt diagram needed
2005 DODGE CARAVAN
196,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
CHRISTINA NINA
MEMBER
1 POST
We changed the water pump and now we are trying to put the belt back on. can you give me a blown up diagram of the pulley?
Oct 1, 2019 at 9:02 AM
Experienced Mechanic
Here is a picture of the front of the engine that shows the belt route. Let me know if you need more information. Thanks
Image (Click to enlarge)
Oct 1, 2019 at 10:02 AM
CHRISTINA NINA
MEMBER
1 POST
Oct 2, 2019 at 4:01 AM
KASEKENNY1 is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 2, 2019 at 4:02 AM
JOHNHERE
MEMBER
1 POST
I had to replace my water pump but can not get my belt on.
Could you help?
Oct 3, 2019 at 4:29 AM (Merged)
DOCFIXIT
Is this a diagram of your belt routing?
if yes then are you taking tension off tensioner?
Add image or video
Ask a new question
Engine won't start
Check engine light
