Tension-er pulley remove and replace
165,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
SLIMONTIME
  • 19 POSTS
Specifically, are there any specific say torque specs. compression requirements, or details applying to this items replacement? FYI this is a DIY. I am reusing the existing apparatus only replacing the pulley wheel assembly. This is something I have not been able to pin down. Also, any tips regarding the cover plate assembly removal and reinsertion? I would prefer not to break the timing chain cover.
All tips appreciated. Good day!
Jun 24, 2017 at 7:37 AM
  • 55,770 POSTS
Here is a guide that will show you what you are in for when ding the job and link that shows you what it will be like on your car.
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
and
https://www.2carpros.com/diagrams/dodge/neon/2001
Cheers, Ken
Jun 26, 2017 at 7:19 AM
