Can I get the tensioner pulley bracket torque specs?
153,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 85 POSTS
Serpentine belt Tensioner pulley bracket.
Dec 12, 2024 at 9:28 AM
  • 55,743 POSTS
Sure here you go:
Torque Specification for Tensioner Pulley Bracket:
Bolts to the engine block/head: 25-35 ft-lbs
Pulley bolt: 18-22 ft-lbs
Let us know if you need anything else.
Dec 12, 2024 at 10:00 AM
TJMOWBRAY
  • 85 POSTS
Aluminum head, right?
Dec 12, 2024 at 1:07 PM
  • 55,743 POSTS
Here are different specs depending on where you look.
Drive Belt Tensioner Pulley Assembly - 29-44 ft.lb
Yes, aluminum head.
Dec 13, 2024 at 4:46 AM
TJMOWBRAY
  • 85 POSTS
Thanks.
Dec 13, 2024 at 5:22 AM
  • 55,743 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Dec 14, 2024 at 2:10 AM
