well, the power steering pump on the car listed above SE model, and needed to relieve tension for the serpentine belt, didn't know that there was a square on the tensioner to insert a tool to relieve tension. So, the bolt on the pulley was loosened a little too much and it sprang loose which made it easy to get the belt off.
which it was a plus. But now wanting to know if the tensioner bar might of gotten damaged and if it should be replace?
Jan 19, 2025 at 5:08 PM
