Tensioner for alternator replacement?
144,000 MILES • AUTOMATIC
MRS HAVOC
I saw on YouTube it is a 19mm but the only 19mm bolt/nut just spins the belt - where can I find a diagram or a caveman drawing how to remove the serpentine belt?
Mar 22, 2026 at 5:20 AM
  • 55,627 POSTS
I got you covered,
Using SST and 19 mm socket wrench, loosen the V-ribbed belt tensioner arm clockwise. When retracting the tensioner, turn it clockwise slowly for 3 seconds or more. Check out the images (below). Let us know if you need anything else. Ken
Mar 23, 2026 at 7:22 AM
MRS HAVOC
Thank you very much for your concise and accurate response! Because of your response we were able to replace the alternator without removing the passenger tire or the engine splash shield! Thank you Ken
Mar 29, 2026 at 7:21 PM
  • 55,627 POSTS
You are welcome, please use 2CarPros anytime we are here to help. Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you! Ken
Mar 30, 2026 at 12:37 AM
