Trying install drive belt, but the tensioner will not move
230,000 MILES • 6.5L • V8 • 4WD • AUTOMATIC
LLOYDLAR
cannot get movement in tensioner to install drive belt, does not seem to follow the common description of a 3/8-inch socket adjustment as is the common answer.
Oct 22, 2021 at 4:00 AM
SQM
  • 6,383 POSTS
There should be a square hole that you will have to use a 1/2-inch breaker bar and rotate counterclockwise to release the tension on the belt.
Let me know how it turn out.
https://www.2carpros.com/articles/replace-serpentine-belt
Oct 22, 2021 at 4:24 AM
