Temperature gauge climbing
46,000 MILES • V6 • 4WD • AUTOMATIC
JACOB TYE
The vehicle has recently started overheating. I noticed that when I turn it off that the radiator fan continues to run for a while. Then just today the vehicle started overheating. The temperature gauge slowly starts rising until it overheats.
Jan 7, 2019 at 10:55 AM
  • 110,251 POSTS
First, make sure the engine coolant is full. With this new of a vehicle, it's uncommon for other problems, but they do occur. If you find the coolant is low, make certain to use the type of coolant the manufacturer recommends which should be indicated on the over flow lid.
https://www.2carpros.com/articles/engine-is-leaking-oil
If it is low, you will need to check for leaks.
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
If coolant is full, there are no leaks, and there isn't excessive white smoke from the exhaust, then I would recommend replacing the thermostat.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
The directions specific to your vehicle for thermostat replacement are listed in the attached pictures.
Jan 7, 2019 at 11:17 AM
JACOB TYE
The coolant is full and no leaks from what I can see. No white smoke either. I will try the thermostat. Thanks.
Jan 7, 2019 at 11:33 AM
  • 110,251 POSTS
Hi Jacob:
Since we know the fans are working, if there are no leaks or smoke from the exhaust, then the thermostat is my first suspect.
Let me know if this helps.
Jan 7, 2019 at 11:36 AM
