vehicle in park and leave the engine on the temperature rises
190,000 MILES • 5.3L • V8
ROGER NUNEZ
While driving the temperature is fine once I put the vehicle in park and leave the engine on the temperature rises, but does not overheat. I turn off the air conditioning and the temperature goes down and then again when I park and leave the engine on temperature goes up, does not overheat and it does not have any leaks. I do not know what the problem is. I have changed the fan clutch, engine coolant, thermostat and temperature coolant sensor.
Jul 20, 2016 at 3:58 AM
HMAC300
  • 48,601 POSTS
check cooling fan fuse see if it is working or not, also check relay both are in under hood fuse box. it may be kind of a residual thing starting to heat up after turning heavy draw items off. also check radiator for cold spots with engine off. If you feel any the radiator is bad.
Jul 20, 2016 at 5:24 AM
ROGER NUNEZ
This for the input. I checked the fuse and the relay they were fine. could it be the condenser?
Jul 20, 2016 at 1:23 PM
HMAC300
  • 48,601 POSTS
is there a fan shroud on this truck? if it has been in an accident it could be missing which would not allow the clutch fan to not work or there is some type of blockage in front of condenser or radiator. that is the only thing I can think of other than a radiator problem. When it is hot shut engine off and feel for cold spots in radiator if you feel any then the radiator is bad.
Jul 20, 2016 at 10:44 PM
ROGER NUNEZ
Thnxs for your help again do I put in a new radiator,and put in 3 gallons of antifreeze but now it has aa dipping leaking up from over flow on the bottom right side where the plug is did I have to persurize it before. Im a little baffled..
Jul 25, 2016 at 3:43 AM
HMAC300
  • 48,601 POSTS
I don't quite understand on this one. from what you said youput a new radiator and 3 gallons of antifreeze but is leaking someplace? if it's bottom right it may be the hose leaking at the clamp. if it comes out he overflow on tank on side of fender then you may have to much installed and it will stop once it gets to proper level.
Jul 25, 2016 at 5:00 AM
ROGER NUNEZ
No its coming from the over flow hose at the bottom by the plug..it's a hose that runs up the the radiator..
Jul 25, 2016 at 5:04 AM
HMAC300
  • 48,601 POSTS
ok well it may be overfull doing that keep your eye on it
Jul 25, 2016 at 6:08 AM
