Temperatures gauge fluctuations
1998 PLYMOUTH NEON
117,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SCOTTDQ001
  • 15 POSTS
The temperature gauge reads normal most the time, but sometimes goes up to the H mark. Then it quickly goes back down to it's normal range.
Sep 11, 2019 at 7:56 AM
SCOTTDQ001
  • 15 POSTS
Also, I forgot to add that the car isn't losing coolant.
Sep 11, 2019 at 8:06 AM
  • 110,244 POSTS
Welcome to 2CarPros.
Have you checked the thermostat? It could be sticking.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
That is my first suspect. However, if you choose to replace it, I also recommend flushing the system when it is out of the engine to eliminate that as an issue.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Here are the directions specific to your vehicle. I don't know if you have the SOHC or DOHC engine, so I will provide directions for both. The attached pics correlate with the directions.
______________________________
1998 Dodge Neon L4-122 2.0L DOHC VIN Y SFI
Procedures
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Procedures
PROCEDURES
REMOVAL
1. Drain cooling system to the thermostat level or below.
Thermostat/Engine Outlet Connector-DOHC
Pic 1
2. Remove Coolant Recovery System (CRS) hose and thermostat/engine outlet connector bolts.
3. Remove thermostat an O-ring assembly, and clean sealing surfaces.
INSTALLATION
1. Place the new thermostat assembly into the thermostat housing/outlet connector. Align vent with notch in cylinder head.
2. Install thermostat housing/outlet connector onto cylinder head and tighten bolts to 12.5 Nm (110 inch lbs.). Connect the Coolant Recovery System (CRS) hose.
3. Refill cooling system (see Refilling System).
________________________________
1998 Dodge Neon L4-2.0L VIN C
Procedures
PROCEDURES
Removal
Thermostat/Engine Outlet Connector - 2.0L Engine
Pic 2
Thermostat And Engine Outlet Connector - 2.4L Engine
Pic 3
2. Remove Coolant Recovery System (CRS) hose and thermostat engine outlet connector bolts.
3. Remove thermostat assembly, and clean sealing surfaces.
Installation
1. Place the new thermostat assembly into the engine outlet connector. Align air bleed with notch on the cylinder head.
2. Install engine outlet connector onto cylinder head and tighten bolts to 12.5 Nm (110 inch lbs.). Connect the coolant recovery system (CRS) hose.
3. Fill cooling system.
_______________________________________
Let me know if this helps.
Sep 11, 2019 at 12:10 PM
SCOTTDQ001
  • 15 POSTS
Okay, thanks. It's a SOHC.
Sep 11, 2019 at 6:46 PM
SCOTTDQ001
  • 15 POSTS
My guess was the thermostat or the coolant sender switch.
Sep 11, 2019 at 6:49 PM
  • 110,244 POSTS
Welcome back:
It could be either. However, more commonly it would be a thermostat. There isn't any evidence of a head gasket problem, correct?
As far as the sensor, you can remove it and inspect it's operation by checking the ohms of resistance based on temperature. If you want to just replace it, here are the directions and the attached pic correlates with the directions.
_________________________-
1998 Plymouth Neon L4-2.0L VIN C
Coolant Temperature Sensor Removal and Installation
COOLANT TEMPERATURE SENSOR REMOVAL AND INSTALLATION
Fig. 107 Engine Coolant Temperature Sensor-SOHC
Pic 1
NOTE: The engine coolant temperature sensor threads into the rear of the cylinder head (Fig. 107).
REMOVAL
1. With the engine cold, drain coolant until level drops below sensor.
2. Disconnect coolant sensor electrical connector.
3. Remove coolant sensor.
INSTALLATION
1. Install coolant sensor.
- Tighten to 18 Nm (165 in lb) torque.
2. Attach electrical connector to sensor.
Let me know if any of this helps or if you have other questions.
Sep 12, 2019 at 10:33 AM
SCOTTDQ001
  • 15 POSTS
Okay, thanks. There doesn't seem to be any evidence of a head gasket problem.
Sep 12, 2019 at 6:30 PM
SCOTTDQ001
  • 15 POSTS
What makes me think that it's the sending unit, is the problem is intermittent. It doesn't happen too often.
Sep 12, 2019 at 7:05 PM
  • 110,244 POSTS
Welcome back:
That makes sense. Before you replace it, make sure the connector is tight and free of corrosion. Also, make sure the wire to it isn't damaged.
Sep 13, 2019 at 10:41 AM
