temperature sensors
2011 CHEVROLET CRUZE
42,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
KCCAMPBW
getting error message air conditioner shuts down due to high engine temperature. Believe it to be the temperature sensor. Can you tell me where to find them?
Jun 27, 2016 at 4:24 AM
HMAC300
  • 48,601 POSTS
before you check the coolant temperature sensor check all fuses and relays in under hood fuse box that may be the problem to make sure the fan is coming on when it should when air conditioner is turned on. see picture for coolant temperature location.
Jun 27, 2016 at 5:18 AM
