Code P1126
125,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DONALD THOMAS JE
Check engine light code P1126. Temperature sensor i need to locate this sensor?
Jan 7, 2018 at 7:09 AM
SATURNTECH9
  • 30,868 POSTS
I posted the information for the code and where the temperature sensor is located, but with that code you more than likely have a bad thermostat not coolant temperature sensor.
Jan 7, 2018 at 7:28 AM
