Temperature sensor
111,000 MILES • 1.2L • 4 CYL • AUTOMATIC
JESSYCA LEH
My low temperature coolant sensor went on, I filled the coolant it went away. I turned the car on this morning and it was back on but it went off as I drove down the street.
Jun 16, 2019 at 6:58 PM
Good morning,
Your fluid may be low again. Your coolant expands under heat and that's why the light went out.
You need to have the system checked for a leak.
https://www.2carpros.com/articles/radiator-pressure-test
Jun 16, 2019 at 8:09 PM
