Where is the coolant temperature sensor located?
170,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JACKIE OLK
I am trying to find out where the coolant temperature sensor is located at.
Aug 20, 2022 at 12:36 PM
SQM
  • 6,383 POSTS
The coolant temperature sensor is located on the left front of the engine, behind the alternator. You will have to remove the alternator to access the sensor.
I have attached diagrams below for your reference.
Let me know of any questions.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
Aug 20, 2022 at 12:42 PM
