the radiator fan is running until the battery drains, temperature sensor?
2014 BUICK ENCORE
110,000 MILES
SUZIB1889
Hi, the radiator fan is running until the battery drains. Is this due to a temperature sensor and if so which one?
Oct 20, 2023 at 8:03 AM
  • 110,244 POSTS
When the ignition key is turned off, the power is cut from the sensor, so at this point, I don't feel that is the cause.
On the other hand, the fan relays have power at all times (at least two of them). If a relay has failed and is in the closed position, power will constantly run to the fan motor.
I attached the wiring schematic below so that you would have a reference. Here is what I need you to do. First, there are three fuses in the under-hood fuse box that I need you to remove one at a time to see which one turns off the fan. (see attached pic).
Do this and let me know which one does it so I know which relay to check.
See pics below. Note: There could be a constant ground being provided to the relay as well. We need to check one thing at a time.
Oct 20, 2023 at 3:18 PM
