Catalytic converters temperature readings
130,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
ROBBINHA11
I’m measuring the temperature of my catalytic converters with a laser thermometer. How many degrees F difference/hotter should the rear of the converter than the front?
May 25, 2019 at 11:27 AM
  • 110,251 POSTS
Welcome to 2CarPros.
The converter should be running around 500 degrees. You really shouldn't see more than 100 to 150 degree difference.
May 25, 2019 at 11:50 AM
