temperature gets hot
85,000 MILES • AUTOMATIC
JESV
i changed the head gasket, fan clutch, coolant, thermostat and sensor, ambient air sensor, water pump, new BMW coolant and changed the vacuum hose, but the temperature still gets high.
Jun 27, 2016 at 4:36 AM
CJ MEDEVAC
  • 11,000 POSTS
Maybe Mr. Radiator has a bunch of mineral build-up in the vanes?
The Medic
Jun 27, 2016 at 11:01 AM
JESV
would you recommend I flush radiator? what is vanes and where is this located?
Jun 28, 2016 at 12:40 AM
  • 55,710 POSTS
This is inside of the radiator please check this guide out about half way down.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and I would see if the head is cracked by doing a chemical test here:
Please get back to us so it can help others.
Best, Ken
Jun 28, 2016 at 5:19 AM
JESV
Thank you for your reply and help. I did check engine light service and everything that was listed i bought new part and replaced but temp still gets hot.
Jun 29, 2016 at 9:08 AM
  • 55,710 POSTS
You did a chemical check and replaced the radiator
Jun 29, 2016 at 11:07 AM
JESV
I changed the thermostat factory defect i drove around and temp was now okay. My check engine light is still on, keep driving, will turn off on it own is this true?
Jun 30, 2016 at 10:53 PM
  • 55,710 POSTS
You will need a scanner to turn the light off, here is a guide to help you.
Let me know how it goes
Best, Ken
Jul 1, 2016 at 5:01 AM
