temperature gauge & radiator cooling fan
70,000 MILES
MICKEY123
gauge not reading,cooling fan keeps running tried new transmitter but no change, had ecu tested told it was ok. Is this a fault on the dash? here's hoping some one has the answer, cheers mick
May 3, 2013 at 1:34 AM
in most cases, it is the sender unit as the pcm has nothing to do with this control.
who tested it and how????
hope you did not overheat it while it is not working as you may damage the head gasket from this
May 4, 2013 at 7:44 AM
