Temperature gauge pegs, but no smoke or warning lights
1998 TOYOTA COROLLA
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
JV2112
Greetings,
My car just started to peg the temperature gauge after a short time of use. I though maybe it was just a sensor gone bad. I have a Verizon HUM+ plugged into the OBD port and it reports nothing. As of yesterday, it sounds like a hole developed in the exhaust. Loud! And when slowing down, it sounds like it backfires a little. I figured I would take it in to get the muffler replaced, but the temperature issue has me concerned. Can it be as simple as replacing that 19mm sensor? Thanks!
Mar 30, 2019 at 8:54 AM
Good evening,
Yes, it could be the sensor but I doubt it. It may be overheating and does not have to smoke or set a code.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Did you check the coolant level?
Mar 30, 2019 at 12:02 PM
