temperature gauge light turns on while driving
131,000 MILES • 2.0L • 4WD • AUTOMATIC
MICHAEL WILT
But then turns off after a few minutes. After I park, I feel the hood, but it feels normal. I open the hood, but the engine also feels normal. It does not appear that it may overheat. I am wondering if maybe there is a bad sensor, or it that a sign of something more serious?
Jan 26, 2020 at 6:45 AM
  • 110,248 POSTS
Chances are either there is a connection issue or the sensor is going bad. The engine coolant temperature sensor is located at the rear of the cylinder head. See pictures 1 and 2. Check to make sure the connections is tight. If it is, here are the directions for testing.
_____________________________________
2010 Kia Forte L4-2.0L
Component Tests and General Diagnostics
Vehicle Sensors and Switches Sensors and Switches - Cooling System Engine - Coolant Temperature Sensor/Switch Temperature Sensor (Gauge) Testing and Inspection Component Tests and General Diagnostics
COMPONENT TESTS AND GENERAL DIAGNOSTICS
Inspection
Engine Coolant Temperature Sender
1. Using an ohmmeter, measure the resistance between the terminal 2 and ground.
pic 3
2. If the resistance value is not as shown in the table, replace the temperature sender.
pic 4
___________________________________________
Here are a couple links you may find helpful for testing:
Jan 26, 2020 at 10:52 AM
