Everything works as it should until the car is actually driven. It can sit at idle for 30 minutes and temperature is normal. Put in gear and in 6 to 10 minutes at 45 MPH the temp gauge shoots up to hot. Pull over and put in park the temp comes down to a little above normal in only about 5 minutes or so. Warmed up and parked in the driveway in park and rev-ed to 2200 rpm for 5 minutes and the temp stays normal. With a laser temp gun when the gauge reads hot the water pump is around 171 to 181 Degrees F. The transmission cooler is 86 degrees and the radiator about the same. The Transmission oil pan is 130 I can find nothing on the engine that is over 180 degrees except the Exhaust manifold.
Aug 24, 2022 at 2:18 PM
