Temperature gauge not working
150,000 MILES • 2.4L
TORRES13
I already replaced the temperature sending sensor.
Dec 17, 2019 at 7:45 AM
So if you replaced the sensor then the only thing left is the wiring to the cluster and the cluster itself. I would suggest checking for voltage at the cluster on the purple and white wire. If you do then the cluster is the issue. If not, then you need to run a new wire.
Let me know if you have questions but I attached a self test that you can try to run but I suspect the wire is the issue so this may pass.
Dec 18, 2019 at 11:30 AM
TORRES13
Appreciate it.
Dec 18, 2019 at 12:06 PM
