fluctuating temperature gauge
220,908 MILES • 3.5L • 4 CYL • 4WD • AUTOMATIC
JAM12345
My temperature gauge keeps on fluctuating, it starts in the middle and it almost goes up to the top. Back in May 2020 the water pump, radiator fan and new coolant were all replaced. What could this issue be?
Dec 18, 2020 at 9:14 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Have you noticed if the car is overheating? Is it running at normal temperature or boiling over? Otherwise it sounds like you might have a faulty coolant temperature sensor. Here is a tutorial showing how a coolant temperature works and symptoms
for you to look at:
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
The coolant temperature sensor is located on the back of the engine near firewall in the back of the left cylinder head. I've attached picture steps below on how to replace for your car. It shows the location also. Hope this helps and thanks for using 2CarPros.
Dec 18, 2020 at 12:41 PM
JAM12345
My car is not overheating and it's running normal temperature, but it will get to normal temperature then it will get close to the H. I'm going to read more info about your answer. I appreciate it.
Dec 18, 2020 at 2:23 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Let us know if you have any more questions on this issue. Thanks again for using 2CarPros and we hope you will use our site again in the future.
Danny-
Dec 18, 2020 at 2:27 PM
