Temperature gague stays on hot.
170,000 MILES • 4.6L • V6 • 4WD
FREDSRAIDERS
I have replaced the thermostat, temperature sensor and radiator due to a bad leak. But my temperature gague goes up to hot as soon as I turn the truck on. What is my possible problem? Or solution?
Apr 18, 2017 at 12:31 PM
CARADIODOC
  • 34,415 POSTS
The wire to the coolant temperature sensor is grounded. That's a red / white wire. There should also be a diagnostic fault code set in the Engine Computer related to "Coolant temperature sensor voltage too low". On most vehicles that code will also turn on the Check Engine light.
Apr 18, 2017 at 1:26 PM
