Temperature Gauge
240,000 MILES • 1.3L • 6 CYL • 4WD • AUTOMATIC
EJENKINS
Gauge needle jumps just a inch from the hot mark, but not running hot.
Aug 15, 2016 at 12:01 PM
HMAC300
  • 48,601 POSTS
check fluid level in coolant bottle and make sure it is filled to mark. check to see if cooling fans are working including one when air conditioner is on, then check fuses and relay in under hood fuse box.
Aug 15, 2016 at 11:10 PM
