temperature was always going up to one hundred but never gets to the max line
165,785 MILES • 2.9L • V6 • 2WD • AUTOMATIC
BUNITE
The temperature was always going up to one hundred, l check the top gaskets, they were still good, l replaced the thermostat with the housing, as l found out the seal could not be replaced.
But the temperature is still going between ninety and ninety five, or max one hundred. it does not get to the red line.
Sep 22, 2016 at 8:58 PM
  • 55,770 POSTS
Hello, BUNITE
It sounds like it might be a cooling fan problem or a problem with the radiator being plugged. Here is a guide that can help.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please let us know what you find so it will help others.
Best, Ken
Sep 25, 2016 at 2:33 PM
