Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Vauxhall
Zafira
Climate Control
Heater
Smell
Can smell warm coolant after driving thirty minutes
2007 VAUXHALL ZAFIRA
150,000 MILES • 1.8L • MANUAL
NEIL WILLIAM GRIMMER
MEMBER
When my car has been on a run after about half an hour I can smell warm coolant inside the car through the heaters.
May 30, 2019 at 5:30 AM
JONNYB1963
Experienced Mechanic
My experience with this sort of symptom is that the heater core is leaking, or related one of the related hoses/fittings is leaking.
Are you able to notice any steam inside the vehicle under the dashboard?
Regards
Jon
May 30, 2019 at 5:46 AM
MEMBER
Hi, there's no steam or anything and my coolant level stays the same but the engine feels really hot after half an hour.
May 30, 2019 at 5:52 AM
JONNYB1963
Well, the safe thing to do here is to have your coolant system pressure tested. You can do this yourself if you have the right tools.
See this link on how to do it:
https://www.2carpros.com/articles/radiator-pressure-test
Regards,
Jon
May 30, 2019 at 6:28 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
